http://www.highaltitudeimports.com/showthread.php?p=306480#post306480
That sucks… but I’m sure things will work out. Hope you fix or change the radiator. Good Luck ![]()
well that certainly sucks. what about using wire? in fact the fastener section of max boost kinda came up short so i wanted to address that in a new thread.
nm. im just gonna tack weld a thick wire over each nut. or possibly use a washer that has a tab, you bend up the tab, then run a wire through a hole in the tab. they use these on turbos except without the hole.
at least it wasn’t for good— the last ride my car took was on a trailor and hasn’t seen a new motor since… im punishing her! muahaha!
