my ls-t to ls/vtec-t
update on whats going on with my car. it’s still not tuned yet but that will be done soon. i’m in the process of trying to make it more of a sleeper. so far i raised it, gsr blades, hood bra, black intercooler. im in the process of installing a 92-93 front bumper to be able to keep the grill and a stock axle back with an electronic cutout. been thinking about 15" steelies with some oem hub caps also…
here’s my old setup. stock b18a at 300whp 292lbs-ft tq
new setup. ls/vtec turbo. not tuned yet. hoping for 400whp+
turbo setup
-GT2871R with .64 A/R turbine housing
-custom fabricated RD turbo tubular manifold
-custom fabricated RD turbo stainless steel intercooler piping. 2.5" coldside, 2" hotside
-custom fabricated RD turbo 3" turbo back exhaust with 22" resonator, magnaflow muffler
-tial 38mm wastegate with open dumptube
-turbosmart blow off valve
-turbosmart dual stage boost controller
-28x7x2.5 2.5" in/out intercooler
fuel management
-precision 880cc injectors
-walbro 255lph fuel pump
-b&m fuel pressure regulator
-tuned with crome pro gold
ls/vtec
-skunk2 dual valve springs
-skunk2 titanium retainers
-skunk2 pro cam gears
-skunk2 intake manifold
-eagle H beam rods
-8.8:1 Wiseco pistons
-custom fabricated RD turbo oil catch can with -10 AN fittings/hoses
-2" half size radiator with 13" spal puller fan
-K&N air filter
-innovate engine mounts
-professional products harmonic damper
-professional products 68mm throttle body
-stock cams (b16a)
-ACL race bearings
-OEM type-r timing belt, type-r water pump, type-r oil pump, vtec headgasket, valve seals, crank seal, cam seal etc. aka everything new oem
-decked head/block, valve job, cylinder hone 81.5mm bore, stock crank.
transmission
-GSR YS1
-action 2MS dual pressure plate
-clutchnet.com 6 puck sprung clutch disk
-Mfactory helical LSD
suspension
-koni yellow
-ground control coilovers 450/350 with extended top hats in front
-prothane full bushing kit and es bushings for the ones that dont come in the prothane kit
-SPC front adjustable balljoint 3*
-skunk2 rear camber kit
-ASR rear subframe brace
-jdm 23mm type-r rear swaybar
-GSR blades with 205/50/15 falken azenis 615k
brakes
-brembo blanks
-hawk hps pads
-goodridge stainless braided lines
-ate dot 4 super blue racing fluid
interior
-GSR cluster
-momo bucket seats
-striped rear and carpet
-autometer gauges oil temp, water temp, boost/vacuum, oil pressure
-innovative lc1 wideband
-b&m fuel pressure gauge (on the fuel filter)
-b&m dual bend short shifter
-skunk2 weighted knob
-TWM 4" shift extender
-momo monte carlo steering wheel and hub
thats the most of it.
looks good what u do internally?
Is that stain on the underside of your hood burnt paint from the heat of the turbo?
yep. well it’s from the manifold. you can also see it a bit on the outside. i’ll get a list of the internal work when i come back from work tonight.
thats some tight clearence on that breather line. looks good man:up:
Hey red, what size is your FMIC thats the size i was looking into running on my db1, im also gonna build the same Style charge piping as your hotside since i cant seem to find a cleaner way to run it i love your car man keep up the great work
block consist of srp pistons, eagle rods, type-r oil pump, type-r water pump, the rest stock and all rebuilt.
head consist of skunk2 retainers, skunk2 dual valve springs, skunk2 intake manifold, the rest stock and rebuilt.
nothing insane but no reason to go overboard for a 400-450whp setup either.
trans is a gsr ys1 with mfactory lsd. b&m dual bend short shifter, TWM 4" shift extender, skunk2 weighted knob. love the combo.
running no timing belt cover doesnt help:uhoh: but it’s really solid even not bolted down i cant push it into the belt. however the dumptube and radiator, now that’s close.
28x7x2.5
good idea for the hotside i love my hotside pipe. thanks man!
received my dual stage boost controller today :up: just got to put a bit more mileage on the engine before i hit the dyno. i have a bunch of pics but i dont know what to post. my old thread got deleted and i had posted a bunch of stuff there. oh well.
cell phone pic of my interior
looks real good. Very clean. Keep up the good work. I’d like to see some numbers when your done. Good luck with everything.:clap:
Lookin gooood! :smiley: I don’t know if you posted this what turbo are you running and I know you haven’t tuned it yet so you don’t know the power change but how does the power difference feel?
haha dont worry once it gets tuned i will have dyno sheets and vids.
i have a GT2871R with the .64 a/r turbine housing. ill edit my original post with some info of the car. i kinda just posted a couple pics real quick but i’ll try to elaborate on my setup a bit. for the power difference i can’t really tell you since right now i have a type-r basemap so i cant boost. however from dyno sheets i’ve seen HP goes up and torque goes slightly down at the same boost levels. so im expecting to stay around the 300lbs-ft tq and be in the 400’s for hp. with higher rev’s and the shorter trans. should be a very fun setup. can’t wait to beat the shit out of it :slight_smile:
[QUOTE=redtegra;2169210]
running no timing belt cover doesnt help:uhoh: but it’s really solid even not bolted down i cant push it into the belt. however the dumptube and radiator, now that’s close.[/QUOTE]
haha no kiding.
300 ft/lbs of tourqe. ohh man that should be fun in a teg:rockon::up::up:
not gonna lie, it was absolutely nuts. if i floored it in third gear at 100km/h i would loose traction and hit the cutoff. highway pulls were a little tricky with the open diff it would shoot me to the right side.
in the handling department i’ve got a decent setup
-koni yellows
-205/50/15 falken azenis 615k
brakes
-brembo blanks
-hawk hps pads
good luck on the new set up hope you hit those #'s. i have similar set with borg warner s300 serious turbo. made 410whp on 15psi 520 on18psi
hey buddy. looking good.cant wait to take some pics together!:slight_smile:
Looking good bro. Your setup is similar to mine so I’m keeping an eye on this since I was debating adding a VTEC head too, want a little more than 300whp too LOL :giggle:
Yup! Sure looks like you got a good set up going! :rockon:
Let me know if you are gonna take pics. I gotta see this thing.
forsure u can join us if ur down!!!
