Just back from the dyno used some race gas this time managed 196 whp@10.5psi. Stock internals standard compression I’m very pleased. Is this enough power to run 13s in a integra 1200kg or less.
Don’t mean to seem negitive, but shouldn’t you be closer to 240-250 whp? The basic turbokits I have seen run anywhere in that ball park. Is there any way that you can post your dyno sheet and your mods? 10psi is a fair amount of boost for a stock motor. But at the end of the day, if your happy thats all that matters. I think you have alot left that just needs tuning to be extracted out. Thats just my 2 cents
My bad man, its just now I saw your sig. SOHC, your right in the ball park. Good for you:D
Yeah she’s just a little 1600 sohc I’ll run the higher boost only when racing guys tell me you can run 10 psi everyday but I’m not going to pay for race gas every dam day. Check out www.fmax.com they boosting 13psi daily on pump gas?
are you sure that’s the right webpage?
http://www.f-max.com/hondacuraturbosystems.htm
Sorry this is the one.
You may want to look into water, water/alky, or propane injection. All of which will allow higher boost on lower octane fuel instead of running race gas everyday, as long as your stock rods hold up.
