i allready searched the site and found nothing. also went to xenocrons page and looked at some bins but found nothen close. my set up is a 95 jdm b18b
t3 .42/.48 turbo with rc 440 injectors, 3inch full piping with a skunk 2 racing series muffler. Also got a jg Redline series head and im pushing 10 psi. it was on a safc 2. it was running great till it started to blow smoke then realized that it was burning way to rich. now it wont even start because my spark plugs are being drowned with fuel. any help would be greatly appreciated. thanks
if nobody has a base map for you to use, you might want to search xenocron’s site… He has a program that will make you a basemap… I think it’s called BaseMapper Deluxe
base mapper delux… sounds like a great program but i kind of wanted a map in which somone allready has tuned and tried it out you know what i mean? but i guess if all else fails. i found this map but im not sure if it will be ok if i use it. what do you guys think:
ian new final 2.bin
Built b18b, t60 turbo, 10psi, 440cc injectors, 3" dp and exhaust, uber 1.7
for one thing, my b series isnt built, and also dont have a t60 turbo but do you guys think it will work? c’mon guys hook a fellow teg member out:clap:
is that it? thats all the help and opinions i get? c’mon…:pupeyes:
sometimes you just have to suck it up and do it yourself, people can’t always have the exact same thing as you and hand it over to you.
Good luck finding it though, but if not, get yourself a wideband and learn to do it yourself You might find it quite fun.
if your obd 1 then you need to check out pgmfi.org. Got to turboedit and there you should find a base map.
here is where you can find a couple:
http://www.xenocron.com/bins/index.php?PHPSESSID=d19b2c89bd4fc0441ee0f826f4d105fd&direction=0&order=&directory=TurboEdit
hope this helps.
