basically I need to remove it since my car was considered a total loss…
Removing all the piping, intercooler, wastegate are quite simple.
everything is self explanatory but can someone give me step by step instructions
just got thru removing all the pipings, intercooler and now ready to remove the manifold w/turbo and wastegate attached.
After draining the oil… can I disconnect the oil line?
Yes the oil line can be disconnected, there may be a little residual oilleft but no big deal. Remove the wastegate, and the bolts for the downpipe. Not sure how yours is setup, I have to remove my front crossmember from the drivers side lower control arm to get my downpipe off, no big deal either. Then remove the exhaust manifold with the turbo attached.
