Does anyone have a diagram of how all the vacuum lines hook up on a turbo teg. It would help if someone could post up some close up pic’s of the intake manifold, turbo, wastegate, and blowoff valve area. I just wanna make sure I do it correct…
Thanks, Steve
I’ve looked there (excellent resource btw) however I cannot find what to do with the vacuum line coming from the thing on top of the throttle body…if anyone can snap a photo of this area that would help alot.
take a picture it might help!
There are 2 vacum ports on the throttle body, assuming your still running your stock throttle body. The middle port runs to the charcoal canister (emissions). The other one runs to the map sensor.
thanks guys, the one I was referring to was the throttle body dashpot…I have since found the info I needed on it.
