new to turbo
hey i am building a setup for my 91 and im trying to figure out what needs to go and what needs to stay also if anyone has any tips or instructions it would be awesome…thanks guys
TUNE TUNE TUNE! MAKE SURE TO TUNE!
Injectors are a must. and what ever you do, DO NOT BUY a EBAY TURBO KIT!!!
hey what do i do about the cooling lines ? is there a way of tucking them in?
do alot of research!
read the g2ic guide. That should help you out…
are you building your motor? if not make sure you motor is healthy, do a compression and leak down test. and as mentioned definitely read the turbo guide and understand it.
thanks it definitly started makin more sense any more tips?
Everytime you change your oil (every 25,00 to 3,000 miles) you should change your spark plugs as well.
Do you have a build part list yet?
There are a few things we need to know to help out better.
what kind of power goals?
what kind of budget?
when do you want it done by?
is it going to be your DD?
i have a parts list started and mostly building the kit from various kits and ive been told i could make 200 whp with my 14b on my sock da b18a
if 200 is all you’re looking for, then that 14b will be fine. although I think you’ll get tired of 200whp and want more.
i figured that but its my first turbo and im building it myself so i definitly see an upgrade in the future
so ive decided to scrap the turbo idea on the b18a and i just bought a b18c5 whats your take on putting the c5 head on a a1 block cause the c5 block blew but the head is good??
try to find another b18c block. otherwise you’ll have to build your b18a block to use your head to its full advantage. and even then a b18c block will be naturally better since its designed for that head. btw im not anti ls/vtec i have one myself but cant deny the facts.
yeah thats what i was figuring and i was thinking ls/vtec but this just landed in my lap so i went for it and for the price i couldn’t loose out on it
