Can anyone school me on nitrous systems cuz I just got a nx express system installed and after install I noticed it goes into the fuel line after the fuel filterbut before the preSsure regulator and also it has a noZzle for the intake tube…now here’s my question is that considered wet or dry or both?:umno:
pix
Wet = N20 + additional gas is added to compensate the fuel mixture against a lean condition, regardless of where its injected (air intake or manifold)
Dry = no extra gas, its riskier, be glad you did not buy that style
what about zex they have the smart box witch bumps the fule pressure
The smart box is wet since it adds more fuel. It has its downsides but serves its purpose for mild N20 use.
whoah b4 you guys confise some ppl.
wet nitrous = nitrous and fuel atomized and injected together at the nozzles. so you dont end up with an issue where more nitrous goes into a single cylinder with the fuel being spread even as it comes form injectors instead.
dry = nitrous by itself usuall single nozzle, and bumps up the fuel pressure in many kits such as zex. you still recive fuel enrichment from ur cars regular fuel injectors. if your only shotting the lower amount this is fine, and you can benefit from the dry nozzle being hooked up further away from tb for maximum cooling of intake charge as well
I am using the NOS WET Sniper…version…
It does a good job…at leaving the police…when they chase after me…
But, when they stop and catch me…they tell me “Shit you’re an old man, what are you doing driving this fast…?”…
wow thats the dumbest thing i’ve heard in awhile
[QUOTE=prior8t2000;2090987]I am using the NOS WET Sniper…version…
But, when they stop and catch me…they tell me “Shit you’re an old man, what are you doing driving this fast…?”…[/QUOTE]
and that wins 2nd btw … lol
only advantage to a dry kit is if you have a dry kit with bigger injectors and some sort of tunnig … other wise on a honda its wet or bust… specially above a 75 shot… but my buddy had a b20/ls with a 115 dry shot with the dizzzy retarded all the way and that lasted 2 years and about 25+ bottles
