nitrous with skunk stage 2 cams
is it possible to spray a 75 shot with skunk stage 2 cams? thanks in advance
why wouldnt it be?
TurboG2teg311 why wouldnt it be?
skunkstage2 cams are pretty large. i wasnt sure if the nitrous would be wasted by the cams being so big. i want to confirm that or otherwise by experiance no2 users?
wasted???
How is that even possible. Kind of like my 1991 JDM integra TYPE-R…
no nitrous cannot be “wasted” if anything you will be making more power than you would without those cams, remember generally things that make power NA will make power with nitrous. :up:
It will be fine as long as you factor in the compression of your motor before you spray.
it is possible that the overlap of the cams could blow some of the N2O out of the exhaust port. Its the same rule that applies to high overlap cams on a Turbo application. People use 404 cams on turbo motors yes, but they also dial out the overlap with gears. more overlap lessens dynamic compression by keeping the exhaust valve open while the piston starts to move up. Keeping the valve open helps get more exhaust gas out so that more fuel and clean air can come in for a more powerful combustion. As for them beeing to big, I dunno, try it out
