I think I’ve been misinformed or have misunderstood how to set up the catch can for the PCV system. Right now I’m using a non vented Greddy oil catch tank and I’ve got it set up as a closed system like the system suggested in the G2IC turbo guide. I just realized that I have overlooked that fact that the catch can is non-vented like the moroso breather tank that is in in the guide. So I’m pretty sure I’m running a fucked up system. I’ve already tapped the two fittings into the preturbo intake piping so I really don’t want to have to mess around with trying to remove and/or plug those. Should I be able to just put a T fitting on the line for the pre-turbo intake line (not the line that returns to the valve cover but the one that comes off the tank) and put a breather filter on it to achieve the same effect as having a vented breather tank?
This is what I’m thinking : (original image credit to G2IC Turbo Guide)
