First off i want to say that i am a huge fan of G2IC…and with that said i have a 1993 acura integra with 212,000 miles on it and i just got a Kit that includes Garrett T3 Turbo , FMIC Intercooler , Blow off valve , Piping , Hoses and turbo injectors. Now my question is what do i need to buy to make this kit function on a daily driver without causing damage? From what i understand the kit will push 6psi if just bolted up. And inorder to push more than that and do it safely i need to upgrade…fuel injectors, add low compression pistons, boost controller, and a T3 turbo manifold… My fuel pump is stock as far as i know and is getting weak so i know i have to replace it but ive been putting it off for such a chance as this. Now keeping in mind that im on a budget what should i buy products wise? Thanks guys i knew if there was any questions about this car this would be the place to turn.
Well first, your question was so broad that no one will be able to answer what you want to know (i.e. Garrett T3 turbo, bov, injectors, etc…). That tells us absolutely nothing. Be more specific.
Two, read the turbo guide and take a few weeks/months to do some research. HTH
Chris
ok my general question is will this kit bolt up and be able to run 6psi and be stable as a daily driver? If not what do i need to upgrade?
you’re not reading properly. what trim/ar is the turbo? what size are the injectors? how big is the intercooler?
what else do you have for fuel management besides injectors? that’s not the only thing you need.
of course, if you’d take a couple hours to read the turbo guide you’d know that.
