Obd0 And 3 bar gm sensor?
Didn’t know where to start this but i searched and Googled a lot and still couldn’t find a diagram or a post of someone saying how to wire in a 3 bar map sensor to and obd0 harness. I’ve found post on other harness and wire colors aren’t same, also saw somewhere to look for VOG on the map sensor/connector on the original sensor and i couldn’t find anything.
Has anyone attached a gm 3 bar sensor to a obd0 harness?
Don’t know if this will help…A is the ground, B is the map, C is the voltage (power)… so grn/wht is A, wht is B, and yel/red is C.
i have a gm 3 bar in my obd-0 integra wired into the stock harness ill take a look tommorow and let you know what goes where
green/white to black, white with red dots to green/red, yellow/red to brown and yellow. hope this helps
Thanks this helped
After looking around i noticed i was looking at tps wires and forgot map was located on the firewall.
got everything solder and heatshrinked
