I have recently noticed that my car has been somehow consuming some oil. I’ve checked for leaks, burning, and can’t seem to figure out where the oil is going. The only thing that I can see is the cam seal plug(front of the distrib.) is leaking. Could that cause my oil level to go down??
I know it’s normal for Honda’s to eat up some oil between oil changes… but perhaps having a Turbo will make it worse?
I’m having the same problem as well… but I noticed that my oil pan gasket has a super tiny leak… so I’m gonna replace that and see where I stand. It’s sooo frustrating knowing my teg is eating oil, and not know where it’s going!
I’d also like to know if adding a turbo kit would make it worse… hopefully some knows…
Originally posted by TypeSZero The only thing that I can see is the cam seal plug(front of the distrib.) is leaking. Could that cause my oil level to go down??
Yup. It can also decrease your oil pressure. Wipe that area down really clean with a rag, and drive around a couple of days… then check that spot again… it’s most likely time to get a new cam seal… STR maybe???
I haven’t noticed much more oil consumption than when I was NA. May depend on how hard you drive, but probably shouldn’t be enough to notice. Also, if your burning oil now, you may want to consider a rebuild or build up prior to going FI. Turbo will definitely make smaller problems become big ones, if they go un-addressed.
