Oil filter Block Adapter
Im in the process of installing my turbo kit, and someone came across that i should use the greddy oil filter block adpater to get more pressure to the oil lines, and second that it is better because im using better oil to the turbine, what do you guys think about it…what are you guys using for the pressure for the turbine to get oil, is it really worth buying and using???
