this greddy turbo is driving me crazy…anyways, i recently noticed the turbine is shooting out oil…where to suck air in. it shoots out oil if i pull it. bad seals i guess? I have no turbo timer so i just stay in the car for good minute but half of the time i get lazy and wait maybe like 15 seconds and turn off the car. the mod i have is only stock motor with the whole greddy turbo kit.
Check your airfilter first. If it is dirty that can happen.
sounds like bad seals in the turbo. you might want to run an oil restrictor first to see if it helps. if not then you will have to get a new turbo or get that one rebuilt. good luck
I checked and took out my filter and there is oil. i forgot to mention that bluish/whitish smoke coming out of my exhaust. this never happened till after i put on the s300. I’m lost here.
should I rebuild this greddy turbo or should i get a new one? i only want 300wph and the car will be fast as is. will the .63 oil restrictor from xenorcon fit in my turbo? waiting for ‘yes’ answer and buy from xenocron right away.
