oil line
i got everything i need to throw on my turbo kit .besides a resistor box and a oil line… as for the oil line my boi said he used a highpress. fuel line ? how would that hold up …as for looks i dont care
Earl’s and Goodridge lines, they are meant for brake lines but you can use it for your oil feed and return lines. Aeroquip makes nice couplers/connectors for the return lines.
with high temp fuel line you will most likely be sending way too much oil to the turbo and you will have to run a restrictor or you will blow out your oil seals and will be smoking like crazy. best be is to go to any performance shop and pick up about 48" of 3an ss line and two 1/8" fittings. itll run you about 30 bux and will be perfect.
you really need to run -3 oil feed line or else some sort of restrictor.
alright thanx for the advice im gonna just order a oil line
tunertoys.com or stealthmodeperformance.com have great oil lines for only $80.
i highly recomend stealthmodeperformance.com make sure you a get -3an line
their quality is excellent and price isnt bad either
you can piece together a kit yourself for half the amount, using the same stuff.
as long as you know exactly what size line, thread/pitch fittings, & know how to put it together… :up:
good luck, dont run fuel lines, or even those fuel lines with SS braided… i did, blew smoke… hahahaha
brake lines for feed I’ve ran in the past. That expensive red or black hose at napa for the return, high pressure stuff.
i picked up a feed line for 35$ as for a return im just gonna use high press hose
