I sold my car over a year ago and I’ve been holding onto these parts in hopes of a future DA project. With everything going on in my life currently I doubt that will happen any time soon. I had started collecting these parts for my car as I was planning to do a ground up restoration of my DA and as you guessed that never happened.
A large portion of the parts are BNIB and are discontinued from Honda. I have been collecting these things on and off for over 10 years. I currently am only interested in selling items as they are packaged (not interested in parting out the groups of parts). Not in big rush to move this stuff but it would nice to clear out the basement…
I’m located in Toronto, Ontario, Canada. Shipping and Paypal fees are extra and all prices are in USD. I will only ship to confirmed addresses. Please keep in mind these are coming from Canada so you may incur duties or taxes when the package arrives.
If you have any other questions you can contact via email at: bizarre52@gmail.com
5. Used Sunroof Visor for DA Integra: $120
In decent condition, includes the clips/hardware
Photos: [IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c5.staticflickr.com/9/8801/28704826604_3372c2aeb8_c.jpg”}[/IMG2]
9. OEM Acura Mudflap Set $80
These were on a 2dr and 92-93 rear bumper (if it matters). In decent shape, the passenger rear mudflaps has some rubbing marks. Only comes with some of the hardware/clips. [IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c3.staticflickr.com/9/8366/29294156466_119f16bf53_c.jpg”}[/IMG2]
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c7.staticflickr.com/9/8542/29040238870_4586be1d0f_c.jpg”}[/IMG2]
10. OEM CDM/JDM Arm Rest $240
OEM Armrest in black from CDM GSR (I believe it’s the same as the JDM). In decent condition. As usual cup holders clip is broken/missing and some minor rubbing marks on the side from the seat belt buckles. The foam is a little squished but not too bad. Also includes the mounting bracket which most people never have! [IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c1.staticflickr.com/9/8150/29040237520_8462572dfc_c.jpg”}[/IMG2]
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c2.staticflickr.com/9/8869/29249027121_c12dfe59b0_c.jpg”}[/IMG2]
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c7.staticflickr.com/9/8500/29040236670_d699a3c0cf_c.jpg”}[/IMG2]
10. OEM CDM/JDM Arm Rest $80
It’s not in the best shape. It was originally Palmy Blue and painted black. Its missing the ashtray, parking brake rubber trim, mounting bracket and inside storage compartment. Obviously the cup holders are broken. I’m fairly confident someone had originally stuffed a CB radio inside of it (theres a bracket for the mic mounted to the armrest). There was also my failed attempt at re-stuffing the foam in the armrest lid. It would be great for a project/restoration as the majority of the key parts are still there… [IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c6.staticflickr.com/9/8430/29249026421_7114ccc51d_c.jpg”}[/IMG2]
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c5.staticflickr.com/9/8254/29040235740_0c749c28ed_c.jpg”}[/IMG2]
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c1.staticflickr.com/9/8513/28704902024_f298ef12c0_c.jpg”}[/IMG2]
10. OEM CDM GSR Cluster $200
Was working perfect when removed. It has 213k KM showing on the odometer. The bulbs were painted competition orange so it lights up amber. The blue diffuser was also removed to brighten the face (can be included). Can easily be reverted back to stock by swapping in your original bulbs. [IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c2.staticflickr.com/9/8431/28707011833_4461e30b0f_c.jpg”}[/IMG2]
OEM Honda B16 Timing Belt $50
Brand New never ended up using it
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c1.staticflickr.com/1/524/31571090994_69868da116_c.jpg”}[/IMG2]
Aftermarket Fuel Rail and Braided Hoses $150
MR Gasket Polished Aluminum Fuel rail for B-Series and braided hoses with fittings. The inlet side was set up for OEM fuel filter and the return went to a FPR.
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c1.staticflickr.com/1/353/31571091454_c91e2a6f4e_c.jpg”}[/IMG2]
Polished B16 Valve Cover - $150
Polish job isn’t perfect but still shows well. This is a JDM B16 Valve Cover
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c1.staticflickr.com/9/8358/28707003693_10ea53150a_c.jpg”}[/IMG2]
JDM ITR Centre Caps $50
Came off a set of JDM ITR wheels. There in decent condition, some minor chipping and fading of the finish.
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c1.staticflickr.com/9/8538/28707009553_e94227596a_c.jpg”}[/IMG2]
Polyurethane Bushings - $50
Left over bushings from my energy suspension kit. Includes:
- Front upper Control Arm Bushings
- Steering Rack Bushings
- SuspensionTop Hat Bushings (I think one might be missing)
- Extra Prothane Engine Mount Inserts (USED)
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c1.staticflickr.com/1/294/32413596015_161afd272e_c.jpg”}[/IMG2]
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c1.staticflickr.com/1/719/32413595995_3cda6fa4b7_c.jpg”}[/IMG2]
JDM EK9 Side marker Lights $40
Includes Bulb Harness. There is some minor black overspray on one, other then that they’re in good shape
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c1.staticflickr.com/1/533/31571090914_8caff573f0_c.jpg”}[/IMG2]
NGK “Blue” Spark Plug Wires for B series $45
Almost new, were used for about 500 miles before I parted out the car.
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c1.staticflickr.com/1/732/32413595805_83679b28ab_c.jpg”}[/IMG2]
Rear Wheel Bearings With ARP Extended Studs $40
They were in good condition when removed. Only reason why I changed them were cause I couldn’t run extended studs with the wheels I had. It was easier to swap hub/bearing then all the studs.
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c1.staticflickr.com/1/324/31571091334_f426c504ce_c.jpg”}[/IMG2]
That’s all I have for now, I’ll keep adding more as I keep going through all my stuff
SOLD Parts:
2. BNIB Left and Right Full Rear Quarter Panels for 2dr DA Integra: $SOLD
Custom Made 3" Cat Back Exhaust SOLD
12. GSR “VTEC” side mouldings SOLD
These were recently painted Frost White. In good shape with all clips intact.
8. OEM Option front lip spolier for 90-91 Bumper SOLD
Lip is in decent condition. Looks to have been spray painted black but I believe it was originally white. There is a small crack on the part that wraps around the corner. It was covered in Bondo so I sanded it off to see the true condition. Looks to be a minor crack.
https://c6.staticflickr.com/9/8694/2…b9f8b90a_c.jpg
https://c6.staticflickr.com/9/8322/2…d67411e9_c.jpg
https://c2.staticflickr.com/9/8373/2…bd762059_c.jpg
3. BNIB JDM Thing Moulding set for 2dr DA Integra: SOLD
These are pretty hard to come by now in new condition. Includes all 6 pieces.
https://c5.staticflickr.com/9/8332/2…e38e01ae_c.jpg
https://c8.staticflickr.com/9/8285/2…ac3ea439_c.jpg
https://c5.staticflickr.com/9/8282/2…72178811_c.jpg
1. BNIB Exterior Trim for 2dr DA Integra: SOLD
Basically all the trim/mouldings that go around the perimeter of the driver, passenger and front windshield glass. Also includes new seals/gaskets for the driver and passenger doors (the ones that meet the door glass), as well as the seals that go between the headlights and front bumper. There is also only one roof moulding as the other was discontinued by Honda.
Parts list is as follows:
72391-SK7-013 Weather Strip Left
72381-SK7-013 Weather Strip Right
73430-SK7-013 Right Mould (Top Front)
73480-SK7-013 Left Mould (Top Front)
73870-SK7-023 Left Upper QRT MLDG
73820-SK7-023 Right Upper QRT MLDG
72450-SK7-023 Left Door MLDG
72410-SK7-023 Right Door MLDG
73880-SK7-013 Left Lower QRT MLDG
73830-SK7-013 Right Lower QRT MLDG
74316-SK7-J30 MLDG Roof Left
73160-SK7-013 Windshield MLDG Left
73150-SK7-013 Windshield MLDG Right
73151-SK7-023 Windshield MLDG Top
71102-SK7-013 Right Bumper Seal
71103-SK7-013 Left Bumper Seal
Photos:
https://c7.staticflickr.com/9/8041/2…904363c2_c.jpg
https://c5.staticflickr.com/9/8294/2…0e17fcfa_c.jpg
https://c1.staticflickr.com/9/8009/2…65553402_c.jpg
https://c5.staticflickr.com/9/8523/2…f0f8b416_c.jpg
https://c3.staticflickr.com/9/8412/2…1020c31d_c.jpg
https://c2.staticflickr.com/9/8625/2…e3c3950a_c.jpg
https://c1.staticflickr.com/9/8235/2…d0b8b45c_c.jpg
11. 4dr Rear door handles SOLD
In good condition:
https://c8.staticflickr.com/9/8148/2…0c3297e8_c.jpg
7. Rare OEM Acura Vigor Spoiler: SOLD
These were pretty popular at one point. Spoiler is in decent condition, paint is pretty faded but you’re likely going to paint it anyways. Includes the complete harness for the 3rd brake light. One of the studs snapped during removal but there is more then enough to hold it down.
Photos:
https://c2.staticflickr.com/9/8047/2…e247c695_c.jpg
https://c6.staticflickr.com/9/8199/2…2131188a_c.jpg
What it looks like installed:
http://images2.fotop.net/albums2/xpr…mangosized.jpg
4. BNIB Sunroof Visor for DA Integra: SOLD
Includes instructions and all the clips/hardware
Photos:
https://c3.staticflickr.com/8/7766/2…e9918021_c.jpg
https://c5.staticflickr.com/9/8097/2…cae5338a_c.jpg
6. JDM Power Folding Mirrors for 2dr DA Integra: $SOLD
Includes switch and relay. They look to have been repainted at one point. Both were tested and are working. One of the mirrors is a randomly a little notchy when folding, it might just need to be lubed up. Also, I’m fairly confident the pigtail in the switch is from a USDM integra as it’s missing 1 wire, but you can simply use this pigtail to pin in the additional wire required to your existing harness.
https://c5.staticflickr.com/9/8448/2…33d75729_c.jpg
https://c3.staticflickr.com/9/8319/2…abd2f24a_c.jpg
https://c1.staticflickr.com/9/8424/2…7af8175c_c.jpg
