Hey guys, I am a COMPLETE NOOB when it comes to turbos, anyway im buying this kit for my b16a LS…
Hardware:
- Custom Log Manifold - Reinforced steam pipe, hugs engine block
- T28 Ball Bearing - 5 bolt dump, twin blade compressor wheel, internally gated
- Braided Oil Lines with earls fittings, t piece
- Coolant lines with earls fittings on turbo, anodised fittings and tee pieces to stock coolant sources
- Stock Plumb back Mistu Evo blow off valve with flanges
- Mandrel bend intercooler pipes
- Silicon Couplings, clamps
- Custom aluminium intercooler painted black
- Braided oil drain pipe with fittings on turbo
Fuel:
- 450cc Blue Top Injectors - tested
- 255lph Walbro pump - brand new
Electronics and Management:
- Blitz DTT turbo timer / digital boost gauge
- NGK V Racing 7 heat plugs new x4
- Chipped b16a ecu with basemap to suit above kit using stock map sensor
- Also included is a Microtech MF1 ECU which you can use instead
- Slim radiator fans
- Oil Pressure Gauge
What opinions, good or bad, do you have about this setup ?
Anything lacking ? any limitations ? I can also retain a/c and p/s wooo
your opinions are greatly appreciated
