piston difference?
whats the difference between an 9:1 compression piston wit a inverted dome and a 9:2:1 compression piston flat top?
The difference is just what you wrote 9:1 has a dish in the top of the piston(inverted dome ) 9:2:1 compression piston flat top piston is flat on top (no inverted dome no dish) It only has the valve relief cut in it.
