Pix of turbo setup
:wtf: I did a turbo setup on a 95 integra once… now im working on a 91 RS planning to boost it but i dont know… i checked out the space on it and mannnn it looks almost impossible to have the manifold with the turbo in that space with the front mounts and all…did you have to cut the frame to fit the charge pipe from the IM to the intercooler?..here is the spec of the setup…but not sure if its going to work???
GT30R 63AR
Full Race Manifold
PWR Intercooler
3" dp
Tial 38mm
HKS BOV
RC 550cc
AEM
let me know if you guys have any suggestion…especially how to clear for the charge pipe to the intercooler and the way the turbo sits by the front motor mounts??? :wtf:
Here I’ll direct you to this thread. It should have what you are looking for.
Click me!
RS turbo
What did you guys do with the front motor mount… also i heard you have to cut a hole on the right side frame to get a charge pipe through it…?
cutting a hole in the frame yes depends on where ur compressor sits . with the ss auto manifold i had i went threw the frame
I managed to run it around the radiator, http://g2ic.com/forums/showthread.php?t=134218
the blue car is mine
It is not necessary to cut the frame. I did make a cut where the battery used to be. No big deal. The cross member did require slight modification, nothing a torch and hammer cant handle. The motor mount was untouched and it barely missed the downpipe. What downpipe are you using?
