please help
are rs type r spec 81.5mm pistion good for boost i looked on raceaxis and they say it will be a Compression Ratio of 10:01 on a b18b or thats alittle to high
that compression ratio can work with a good tune but why don’t you buy some aftermarket pistons made for that block? there are a lot of choices out there.
you have any good choice i can pick from
what are your power goals?
250 to 300hp but i have a built head aready and need to built my bottem end and going to get a t3/t4 garett turbo
whats wrong with the stock motor?
so you think a stock bottom will hold up to 300hp
Yea with head studs and a good tune dont spin the motor past stock redline if you do put in some arp rod bolts
On my last setup I made 325whp at 12psi on the stock b18a.
On my next set up which im doing now im shooting for the same hp but with a TDO5HR EVO 8 turbo.
Theres tons of guys who do it check out Honda-tech
ok thanks for the help man
make sure you do a compression and leak down test on the motor first just to make sure it doesn’t need a rebuild.
http://www.g2ic.com/forums/announcement.php?f=18&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
