Hey guys I am almost done with my turbo kit and ran into a problem with my injectors. I have precision 440’s and they are too big to fit into the injector holes (don’t know the exact name). Anyways, is anyone running precisions? I would like to keep my injectors so i could install them tommorow so if there is a trick I am missing, let me know.
you could do the trick that is used with the dsm 450’s, the stiffer injector oring (assuming this is what you cant get it to go into) needs to be bored out a bit to fit the injector, use a dremel and just do a little bit at a time and keep checking it to ensure a snug fit
heres a link on how to do it, scroll down a bit to find out how http://www.hstuners.com/forums/showthread.php?s=&threadid=11436
thanks for the effort, but the problem is that the metal tip on the precision won’t fit through the metal hole in the engine for the injectors…
Would there be any harm in opening up the holes on my intake manifold with a dremel to accomodate the injectors? Then if i wanted to get back to stock injectors, the seals would still do their job, correct?
my precision 780’s fit perfect no mods. those for hondas?
yeah, they were used on a 00 si…
