hey guys i been researching all weekend and came up with nothing
is it true that u need a resistor box 2 run 750cc precision injectors on our DAs (obd1)???
thanks for all the info
The only way u wouldn’t have to run a resistor box if the inj dnt say low impedance.
i bought them used i guess i have to run the part #
I think it would be the best choice. I have sum but there a 1000cc. U might askk the person u got them from or try the precision web site.
thanks i will let u know
did the research and come 2 find out my injectors are 780cc and low resistance. now low resistance is the same as low impedance?
and now how can i rewire a resistor box into my car?
can i get one from an eclipse or prelude or ACCORD?
thanks againfor all the help
ok did some search here and i found these:
http://www.radioshack.com/product/in...entPage=search
how will this resistor would wire up 2 mine harness?
sorry is this one
check out the g2ic torbo guide sticky, u can find what ur looking for and more…
i did thanks i will wiring them up 2morrow keep u post it.
could running these injectors with out resistor will cause it to flood my engine with gas?
thanks
You could burn them up without using the resistor
