here’s the deal,
im in the process of installing dsm 450cc and a resistor box in my 93 DA.
it has an 0bd-0 motor converted to obd-1.
when i try to remove the injectors, there seem to be a small rectangular box atttached to each injectors. (i think its a 10 ohms resistor box)
is that suppose to be there?
should i remove it and continue on , on installing the 450cc and add a resistor box.??
yah that was needed to run obd0 injectors
that means u dont need a resisitor box for the dsm’s anymore
imo
redo the wiring
clean it up a bit and make cleaner connections
by the looks of it
they used the obd0 injectors in which they needed to wire that resistor in
thats what i was thinking, thanks
another problem i ran into,
the dsm clip doesn’t have a common wire? should i reuse the stock ones?(modified)
also since i already have individual resistor attached to my injectors, then i dont need a resistor box do i?
i would take off the resistors and run it with ur box but that’s me. u’ll only need one of those options. your clips should fit dsm by just taking the tab off inside the clip
which wiring from the clip is the common wire that i should use ?
