So I recently purchased a 1992 Integra LS 5spd with 230k on the motor I picked it up for $400.00 because the previous owner thought it was the alternator even though it would turn over and the batter had a good charge.
Car $400
Tow $69
TOTAL $469
After I got it back to my shop I found the car didnt have spark and went down to my friendly Oreilly auto parts for a new Distributor.
New Distributor $131
TOTAL $600
I had previously been looking for a project to put the bottle on so I had a nitrous kit and add on’s in the shop already. Have Purge and bottle warmer and gauge as well as brackets and lines.
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“custom”,“height”:“300”,“title”:“s-l400.jpg”,“width”:“400”,“data-attachmentid”:1115779}[/ATTACH]
Zex Wet Kit $272.50
Tuner Kit $300.00
TOTAL $900.00
I located a Walbro 255 from an old project sitting around on the shelf.
255 Walbro $100
TOTAL $1000
If I am going to be running it then I’ll need lighter wheels/tires than whats on it found a set of beat up Rotas had a set of 15 drag slicks sitting already
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“custom”,“height”:“441”,“title”:“20170912_180853[1].jpg”,“width”:“331”,“data-attachmentid”:1115780}[/ATTACH]
Rotas $100
Slicks Free so old no cracks
Sandblasting $100
Paint $25
TOTAL $1225
Had to transfer the title after driving it a few days to make sure it didnt blow up on its own with no help from me. Seems to run a little rich but plunty good enough for a $400 time bomb.
Title $41
Ins $38
TOTAL $1304
Had to pick up a door at the junk yard other one was caved in also replaced the ricer tail lights with stockers.
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“custom”,“height”:“608”,“title”:“20170910_112851.jpg”,“width”:“559”,“data-attachmentid”:1115782}[/ATTACH]
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“custom”,“height”:“220”,“title”:“20170910_083739[1].jpg”,“width”:“293”,“data-attachmentid”:1115781}[/ATTACH]
Tail Lights
Door $119
TOTAL $1423
The door was black so im sticker bombing it with performance part only stickers love hate it whatever.
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“custom”,“height”:“294”,“title”:“stickers.jpg”,“width”:“294”,“data-attachmentid”:1115788}[/ATTACH]
Wanna Sticker $10
TOTAL $1433
Ordered a window switch for the nitrous activation from summit racing.
Window switch $51
TOTAL $1484
Found an old school timing controller on ebay as well as an AEM Fuel rail and Regulator
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“custom”,“height”:“184”,“title”:“AEM.jpg”,“width”:“362”,“data-attachmentid”:1115786}[/ATTACH]
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“custom”,“height”:“261”,“title”:“timingcontrol.jpg”,“width”:“348”,“data-attachmentid”:1115784}[/ATTACH]
MSD Timing Retard $83.77
AEM Stuff $135.00
TOTAL $1702.77
Needed a new set of corner lights to get it inspected… so thats a bummer but they are on the way.
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“custom”,“height”:“236”,“title”:“cornerlights.jpg”,“width”:“174”,“data-attachmentid”:1115785}[/ATTACH]
Ebay Corners $29.99
TOTAL $1732.76
Still bidding on a older MSD SCI ignition controller for the timing setup… so heres hoping on that one…
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“custom”,“height”:“179”,“title”:“msdsci.jpg”,“width”:“238”,“data-attachmentid”:1115787}[/ATTACH]
So down to brass tacks and please do not answer Technical questions if you have not experience with nitrous and the b18a1 and disregard the mileage what should be my end game shot for the kit its a wet kit from zex and i know i can roll into it with a progressive controller so does 100 shot sound out of the question with 4 degrees retard after coming out of the hole hitting it at WOT in second… and what could it possible run if everything hold together?
Anyone else who has done extensive weight reduction such as gutting the doors or running without door windows?
Thought about lexan but it isn’t street legal and I cant imagine driving in the rain on slicks so if its fair weather only I may remove them.
Thanks in advance for any advise will try to post here daily if the thread needs to be moved let me know?
Will post more pics as I get them.
![20170910_083739[1].jpg](https://forum.g2ic.com/uploads/default/original/2X/8/87dc9edd82c8cbfc3006001930024013f4ea2b1f.jpeg)
![20170912_180853[1].jpg](https://forum.g2ic.com/uploads/default/optimized/2X/1/13f31917b8b216058f2e167744b359cca834a3f0_2_375x500.jpeg)
![20170921_174956[1].jpg](https://forum.g2ic.com/uploads/default/original/2X/e/e37235b41ede659f834f885182e58b59f4e410e0.jpeg)
![20170918_190401[1].jpg](https://forum.g2ic.com/uploads/default/original/2X/9/952c1b2c99b574a0c139a0412b1965b9ce80b8fc.jpeg)
![20170926_213123[1].jpg](/uploads/default/original/2X/4/4a98e0bad28a98cee395c78387ecddf1804df762.jpeg)
![20170926_212948[1].jpg](/uploads/default/original/2X/1/1df8c315c8321477cdef8b3e100961b3109f355d.jpeg)
![20170926_212959[1].jpg](/uploads/default/original/2X/1/1bbaa2c3de6f437b94559347eafd82976f2b3ccd.jpeg)
![20170926_213047[1].jpg](/uploads/default/original/2X/5/58b2ced299d70112f0fc283d92dba791842efbce.jpeg)
