Can I use 2 slim fans(12") in a push and pull setup? I wanted to mount on on the front of the radiator and the other in the place of the condensor fan as im trying to retain A/C. Is this possible or should I stick to a single direction on the fans?
Thanks
MantisX
[QUOTE=MantisX;1683655]Can I use 2 slim fans(12") in a push and pull setup? I wanted to mount on on the front of the radiator and the other in the place of the condensor fan as im trying to retain A/C. Is this possible or should I stick to a single direction on the fans?
Thanks
MantisX[/QUOTE]
i have the simlar setup
12 pull
10 push for ac side
u cant fit 12 on the ac side without cutting that middlebar and moving the ps lines
Cool, good call on the 10" fan on the condensor side. Ill get with xenocron and place an order for the fans. Now I need to figure out how to manipulate the AC lines/windshield washer etc. to get my intercooler piping through that madness of clutter on the driver side.
Thanks
MantisX
not too hard
remove washer bottle,
then coming up the bottle stright for 5 inches then make a 90 down to the ac comp then 90 from the comp to the pass side and a 90 on the turbo outlet
im parting my turbo da out soon
lmk if u want to buy the piping
its 2.5 cold
2.0 hot
edit: n/m i posted wrong info
I am using 2 Hyundai Elantra fans in reverse phase pushing air. Picked them both up for less than $35 at a junkyard. Never overheats and runs only for about 2 mins when I get on the throttle.
