question turbo build
ok im building my motor havent done anything about cylinders and cylinder rods i am goin for a 300hp range wats a good setup to run or can i just use stock or should i go with bigger pistons
how much money do you have for the build?
u want it to be reliable or not?
those 2 questions will decide what route you will go…
i want it reliable and dont wanna go oever 1000 could i use my stock piston rods and get a piston thats bored .20 over ?
the compression is wat im worrying about
Wiseco Pistons - although .020 overbore would be a great idea assuming you’ve got some mileage on the motor
Eagle Rods
ARP Head Studs
there you go, less than $1000 in parts…next time I would suggest doing some of your own research and then coming and asking a specific question.
if u do use stock rods… make sure you put in arp rod bolts
Is boosting a b18a1 with 188,000 miles a bad idea if i change the valve train, rods, and pistons?
