(question)!
okay im thinking of purchasing a methanol kit for the car. if i do happen to go with a methanol kit how much boost do you think it would be safe to run with the proper timing and fueling as well??
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
http://www.g2ic.com/forums/announcement.php?f=18&a=13
Figured I would copy/paste that, if you fix your subject you might actualy get helped.
