quick question on injectors
okay i want to buy some 440’s saturated but my car is obd0 peak and hold
but my question is can i still use the saturated ones cause of the resistor box that the 1990-91 has ?? plz help asap i want to buy em already so i can install by next week
if you buy saturated you would have to take the resistor box out I believe, you could just pick up a set of used dsm 450’s, and just have them balanced and flow checked, it would be cheaper then buying rc 440’s (im assuming) and they would be a direct plug in, just need to fix the orings a bit
Okay I get u but I want some rc 440s cause I don’t wanna get through the hassle of balance n clean and all that stuff for the dsm 450s or is it worth it in saving me money by getting those dsm injectors and getiing em balanced and cleaned also where can I get a chip or something to tune my ecu for the turbo and injectors, a guy charges me $450 to tune it but I have to get the injectors I don’t know anything about tunning
well you can get a set of 450’s for around 50 bucks, you can send them off to be balanced for around 10 bucks each, so that puts it under 100 bucks which is way less then a set of 440’s that would require more modification since they would plug in where the 450’s are peak and hold so its a drop in beside the seals
I can set you up with an ECU or chipping and the injectors all from one place :slight_smile:
It may just be easier to stay with Peak and Hold injectors as well instead of removing the resistor box…
where is that xenon i preffer paypal im very interested :smiley:
where?? very interested for the chipping and injectors :ohyeah: :-*
u dont need to do anything but remove the hard seal to install 450’s…
and resistor box at least for obd1
www.xenocron.com or email me at chrisharris -at- xenocron.com
I have been doing chipping a while and just recently added Precision Injectors to my site.
what about obd0?
