quick question
alright…
i was wondering how long i would need my oil feed and return line to be
simple answer
if you dont got the answer…no need to reply to the thread
Go to http://www.stealthmodeperformance.com/ and order up one of their oil line kits. The oil feed and return length all really depend on the turbo and manifold so they’re really isnt one answer. If your making the oil lines I would get a good 9in for the return and about 3ft on the feed at least. Its easier to cutoff some length than add.
http://www.g2ic.com/forums/announcement.php?f=18&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
