rad clearance
i am thinking of purchasing a 94 and up b-series blox manifold it should fit the b18a right? it says for b-series but also 94 and up and i have a 90, also if i use this manifold, would it give me enough clearance to keep full rad? what about a/c fan?
you might want to look into pusher fans if it is a tight fit. don’t know how much of a clearance issue the blox mani is but I can tell you that we don’t have the clearance the 94+ do between the rad and block.
well if i took A/C fan out u think the mani would fit with full size rad? where can i get a 90-93 manifold that would give me good clearance have have WG position same and blox?
I hear that the inline pro manifold is really good as far as clearance goes…
