what kind of radiator is everyone using? is it a civic one? and where is everyone relocating there battery to?
you can either use the half rad or the full depends on what manifold you are going to use. the best place for battery is going to be the trunk
A 88-91 crx half radiator fits better i believe. Also i would upgrade to a fluyidyne half radiator, cheaper and alot better cooling!
A 88-91 crx half radiator fits better i believe. Also i would upgrade to a fluyidyne half radiator, cheaper then the integras full size and alot better cooling then the stock half size!
does the radiator bolt right up ??? or do i gotta do some mods ???
this is the only thing i need and then i can start the install
oh yeah and you know the pipe from the IM where can i pick one of those up for my ls? or did you guys custom make one? because the angle is to bent and i need another one.
i did it the ghetto way, i just angle the pipe a little and used couplers to help.
it easy to weld a good one though. Im rockin the stock radiator and i used the A/C fan as my “slim fan”
stick with the full rad. you will be happy you did on the hot days.
yeah but damn i aint to sure if the turbo is gonna fit with the stock radiator…and the pipe that i got goes right over the battery and if i relocated my battery the pipe would still be going into the wrong area so i figure just fix the one i have
Stock full sized radiator, stock battery position.
Used the pipe from a CAI designed for the DA:
alright thanks guys im gonna pick up a radiator sometime this week and then do something about that pipe.
