rc 550 injector install problems
thought it was going to be an easy task but i guess not. the rc 550 injectors i got are the same height as the stock injectors, even my rc 310. problem is that the spray tip will not fit into the intake manifold. the rail said goes in maybe 1mm before the o-ring. did i get the wrong injectors or is there a way to remedy this?
are the bottom seals you have in right now the same height as the ones u grabbed from my other IM here? maybe add in a small washer on each of the 3 studs to bolt the rail down to give it room?
o-rings are different. the injector is totally different in the way it mounts to the IM and fuel rail. i guess this answers the question that k-series injectors dont fit a b-series motor.
hahahah aww… these were for a K series? i guess u got injectors for ur rsx then…
lol
obvisouly
