[QUOTE=jdm_livn;2169944]heres a shot of my foglight, i customized mine to work sort of like a 3rd brake light. i took the socket off of some other integra lights, which basically gave me 3 wires instead of the 2 that it comes with. looks good that way and keeps the cops from messing wit you, cause its pretty bright.
so it’s always off? then when press on the brakes it goes on just like a regular third light
The rear fog light option was avalable on RHD cars and was mounted on the left side rear and was used for backing up or parking on side of road, the ones I have seen only work if switch was on and when in reverse, the stock fog light switch was used to turn on a second fog light relay and back-up litght power was run through the relay to the fog light.
You can do the same thing, [use stock fog light switch] and connect the reat fog light up to the output of the stock fog light relay, [all fog light on when switch is on] if you want to drive with rear fog light on, I would check with local DMV to see if it is legal to drive with a fog on the rear first. 94
