ok i just purchashed another 92 GSR so my other project of a superchared gsr has been put on hold cause putting a jackson on a Da is work i dont want 2 do. i like the power of the B17 but i want a liitle more power and i was going 2 go 4 just go with a mild all-motor rebuild cause this is my dd, but my boy talked me into going turbo cause what i can pay 4 cams, headers, intake,etc i might as well piece together a turbo kit. I am keeping the gsr as oem as possible cause these cars are so rare i am trying 2 keep most things honda
Head:
port and polished
type r valetrain
B17 oem cams
ported trottle body & intake manifold
adj cam gears or oem cam gears (opinions)
310 injectors (opinions)
arp head studs
Block:
RS Machine pistons cr of 10.0-9.5 (http://www.honda-tech.com/zerothread?id=1569878)
shortpenned B17 rods
B18c block griddle
polished crank
oem bearings
i want to know if this a good setup for turbo i am only running 5 psi with a max of 10(only at the track) this is my DD
i am looking 4 a small turbo that spools quick and will be at full boost at around 5k i am only looking for about 220 hp
