resistor box question
i searched but just a quick question…will a g1 teg resistor box work for 450cc injectors?..thanx
no in order to run bigger injectors you need some kind of air/fuel controller. i have denso 320cc’s i cant use intill then. if you just put in the 450’s it will run rich as hell. if it will even start.
Assuming he already knew that, 450cc injectors don’t necessarily need a resistor box. It depends whether or not they are saturated or peak/hold. Peak/hold requires the extra impedance. But since 9 out of 10 people use the 450cc injectors from a DSM, I would say yes, you probably need the resistor box and the one you mentioned will work.
spec says your impedance (load) seen by the ECU is 10-13 ohm for the injector settup . then if you use DSM (2 ohm)you need a box (10 ohm) in serie with them.
something strange is that i got a resistor box which i dont know where it comes from and it is 6.6 ohm… hope it will do the job though…
It’ll be fine, that’s about what the resistance was for my resistor box, which I have paired with the DSM 450’s
