I used the evo 2 sliders and I drilled out the spot welds on the feet off the DA rails. I mated them right to the sliders from the EVO. The EVO sliders are now DA rails I first bolted the feet to the rails to get the position correct then I welded them.
I have to look for pics. They came out quite ugly due to using a flux core welder but they are strong and they are hidden under the seats lol.
but it doesn’t even matter anymore because the Recaros are no longer in my DA
[QUOTE=rollinmyda;2310330]I’ll have to check those out. You definitely have some patience! I never thought that light was going to see a car again… Haha
You know I didn’t even notice. I want to say they’re still in there but I’d have to double check.[/quote]
Yeah it was pretty annoying trying to get the lens perfect but the hardest part was making the housing seamless and not need paint.
You have had a few sets of Stanleys, can you tell me if the USDM lower brackets will bolt onto the one piece housings? I never tried it and now that I want to know I don’t have my USDM lights out here with me lol.
Oh I got you.
but from my experience with upgrading master cylinders in multiple chassis the pedal effort change is not noticeable with or without the type r booster.
on my ej6 sedan I have a type r mc and it feels fine with the stock booster. that and the standard dc2 booster will work just as well and are way easier to come by.
The Legend brake upgrade is an awesome choice. Much cheaper than the NSX and they are the same calipers. Just so you know don’t waist your time flipping the calipers to make the pistons go in the “correct” position. It is the most retarded debate ever. The pistons move out of the calipers at the same rate and the minute size difference between the two pistons doesn’t affect the wear of the pads. I firmly believe that the only reason for the different piston sizes is for pedal effort and master cylinder size. The two pistons are identical in surface area to the single piston type R calipers but they just push the load much more evenly across the pad. So in order to save time and money I think Honda just kept making there 1" master cylinders instead of increasing the second piston size and needing to make an odd master cylinder.
So in short just position the calipers so that the bleeders are up to like it should be.
Or do what a friend f mine did and drill new bleed holes on the bottom and seal the other bleeder holes. PITA and not worth the time and effort. lol
And having to flip the caliper up and put a block of wood in it to bleed is really annoying. I like being able to bleed the brakes with my wheels still on the car but that’s me.
Also if weight is any concern to you I was able to shave a total of 2 lbs off of my legend calipers.
I shaved the calipers and brackets with and angle grinder.
Also the whole mini or corrado rotor idea works but becomes trouble some without proper ducting to the fronts. Yes the use of either rotor will allow you to not have to re-drill or order custom prelude rotors and will eliminate the need to shave the caliper brackets but the fact that they are thinner than the Honda rotors they do heat up much faster and are much more likely to warp. I had both the mini rotors and the corrado rotors on my DA and I hated them. I had to machine the corrados three times because they would overheat on me and cause brake shake. then with minimal cuts on them I had to trash them after the third time resurfacing them same with the Minis. I know 3 cuts on rotors seems crazy to some but I have been able to cut my prelude rotors for the third time and they are still within spec. I machined my caliper brackets my self and I have not had a problem and I also re-drilled my rotors myself and I have not had an issue.
Four sets of pads and 3 cuts later my prelude setup works flawlessly.
If you have any questions don’t hesitate to hit me up.
btw I am also going to be running ep3 rears on my teg. I have the complete setup at home I am just waiting to get home so I can install and test them.
I will let you know how that goes lol
Sorry for this novel lol
