Safe to drive car?
i recently put on my greddy turbo kit on my da w/ a jdm gsr swap . i havent takent it out of the garage yet or even started it .
basically my question is is it ok/safe to drive my car with 550’s and a stock fuel pump with low boost? (under7lbs) will it be enough?
i REALLY appreciate the help!
and yes i did search:surrend:
mike
id say yes, but what are you using to control the 550’s ?
a safe basemap from phearable.net(to run the 550’s), basically am i gunna be maxxing out my fuel pump or anything? could i hurt my motor doing this?
anyone?
bump for a answer
i just got rid of my highflow fuel pump otherwise id hook you up.
just go order one from summit they are cheap and ship quick.
the fuel pump will more then likely be maxed out. so just go on the safe side and get a new one. this is where people blow motors, put everything into the motor and not enough into fuel setup.
well i was j/w thanks for the advice!
http://www.g2ic.com/forums/showthread.php?t=146397
As long as the basemap is good, you should be able to drive the car conservatively, even with a stock pump.
