size dosent matter
all right, first off i wanna say is thanks to you guys. g2ic has helped finish my turbo project and i love my teg ever more now. i just wanna here wut you guys think of my set up.
(i was on a budget)…lol
i started with a 91 ls special
b18b complete head …free
log style mani…$100 ebay
Garret t/3 .42/.48 trim (volvo 760)…free
Blitz BOV…free
block gaurd…free
xs power intake mani and fuel rail …$150 ebay
B&m fpr…$20 ebay
front mount IC…$175 ebay
93 bumper…$20…white spay paint $15…lol
custom 2.5" downpipe w/flex pipe and amagnaflow resinator …$200
custom piping…$150
SAFC II…$250 ebay
Exedy racing clutch / ACT 12lbs flywheel…$450 prostreetonline.com
Walbro fuel pump…$100 ebay
complete rebuild… DIY…$75…lol(I work at advanced discount auto)
B&m short shifter…$20 ebay
Skunk2 shift knob…$50 ebay
Accel wires, msd cap/coil…free
beating a fully built LS/Vtec civic buy 3 cars
A GSR hatch by 2
and a built b16 civic with t3/t4 by 1 …Priceless
(you should have seen there faces when they saw under the hood)
congrats on the turbo setup man! sounds pretty f-ing good. Maybe one day i’ll stop spending all my money taking my girlfriend out to restaraunts and actually finish my turbo. heh. Question- how’s that intake mani? i’ve pretty much never given that company a second look since EVERYONE on g2ic had complaints about them. let me know what you think about it? also, do you have any numbers on your setup? et’s, anything? i’m curious to know how your setup throws down.
blowing you engine with a afc hack…priceless.
Ditto…especially if you actually beat those two setups…you must be running way too much boost at too much ignition advance. Your engine doesnt like you right now…
KABOOM when u spike and get towed home.
way to go to the darkside on the cheap. But dont cheap out on the tunning.
Tunning is the key to longevity of a motor and thats priceless
go ahead diss on me. afc hack my ass if it works it works. im getting my ecu chipped with uberdata anyways. im waiting to get it back. even so, im only running 5 psi with the internal waste gate, and yes i did tune it. i put more time then money into this project and it came out great. runs smooth dosent leak or smoke, it runs a little too rich but other then that its awsome. about the xs power intake mani …well it didnt fit all that great but its modeled after a type r so its basically the same thing.
no one is dissing on you…they are dissing the AFC hack. Good that you are doing the chipped ECU thing.
I was not dissing anyone, I was just informing you that your shit will blow within the next 2 months on the afc hack. I tune cars every week, with a wideband, how did you tune without one? musta took a long time checking plugs.
Alright guys i just got done adding some stuff tell me what you think.
greddy type rs bov
crower stage 2 cams
crower dual valve springs
crower titamium retainers
exedy clutch kit
fidanza 8lb flywheel
new axles
head gasket of course lol
If you want to get tuned on uberdata/turboedit/bre LMK, I’m located in Palm harbor. its 20 mins north of cleawater beach. If your willing to drive down here, I can get it done in a night.
deffently need to get it tuned soon. i reved to 8900 while running a bike last thursday night. it spun #1 and #4 rod bearing. so i pulled the engine the next day and disassembled it the next night. im waiting for a crank right now. the crank was turned before 20 thoustants already so i dont want to use it no more… ill prolly have to just have order one from carquest. cause nobody i know has an extra. but anyway after i plastic gauge the crank and blueprint the block ill start putting everything back together the right way.
I’ll be in the tampa area within the next couple of weeks. what do i need to have for you to tune it. remmber its obdo NOT obd1 so let me know if you can still tune it.
you would need a chipped obd0 ecu and an o2 bung 24" downstream from the turbo. depending on how much time I spend on it, figure around $100-150.
aight depending on how soon i find a crank ill let you know when ill be in area. what can you do to the ecu? wut do you mean by 24" o2 bong :shrug: ? and how else can you tune it?
a bung, a place for my wideband o2 sensor to screw into. I will be tunning A/F and timing. I’d rather you convert it to obd1, I like the obd1 rom editor alot better. I’ll get it done with turboedit but, I don’t like it very much.
well, whats in the fully built ls/vtec? FI is a much better value for power. Congrats on your build, but NA builds are usually done with a diff. intent.
