http://cms.skunk2.com/id/634/90-93-Integra-Pro-Series-Camber-Kit/
I wonder if is actually for a DA or not?
No more caster problems
They just emailed me. Yes it’s for the DA and it’s the redesigned version part number ending in 5650. I was pissed when I got the email because I don’t have a DA anymore. I was just about to create a thread. I bumped the old one haha.
I have the last kit new in box… anyone sending their old kits in for the new one?
Finally!
sweet, gonna wait for a review!
Soooo no negative adjustment? Meh, kinda useless…
it is designed for the da. i picked mine up on thursday last week. will post up alignment sheet once done.
Yes please post up the alignment sheet. If it works this time i’m going to pick up a set. Running 4 degrees of camber kills my front tires.
Finally !!!
I`ll wait for the result thanks in advance
Nice. Hopefully these work…Awaiting alignment spec sheet!
ordered mine from WEKSOS yesterday, can’t wait to get them. As soon as i get them on and get an alignment, i will post up my alignment printout.
what’s skunk2 going to do for those that have the previous version? i think they should get a replacement.
i doubt they would replace it, probably charge you less to buy the new one
you can trade the civic kit in for the da kit?
I just ordered mine today along with my lowering springs should have it done and installed by the 2-12-11 will post pics and sheet of alignment.
Still waiting for mine to come in. I hope this fixes the upper arm from banging into the tower on potholes.
ok, so i got my alignment done this morning. her are the results.
front-leftfront-rightsuggested range
Camber:-1.1*****-1.3******-1.0 to 1.0
Caster:2.12.4.05 to 2.5
Toe:0.010.01*** -0.08 to 0.08
so the only thing out of spec is the camber, and i have it set out as far as it will go… I’m not really low, and i’m not tucking tire. So if you are really low your camber probably will be affected even more than mine. With the stock ball joints and a-arms i had -3 degrees of camber and now i’m down to -1 degree. -1 degree of camber isn’t that bad, but they advertise 3 degrees of camber correction, but i was only able to get 2 degrees. over all i happy with them so far, but only time will tell.
Im just got these for the easy adjustability but after looking over a few things my shock towers will still be getting banged up because im pretty low tucking all four. Only reason i jumped and bought them was because the description said it will clear. I really dislike the anchor style camber kits anyway because its so hard to adjust and to many horror stories of them slipping. Fingers are crossed for this!!!
as i was reading through this i figured id price myself a set of these. figured id share with everyone on g2ic that import replacement parts always has great prices here a link…yall are all welcome ![]()
http://performance.importrp.com/skunk2/skunk2_proseries_camber_kit_front/516055650/i-238661.aspx
