Skunk2 turbo muffler
anyone try the Skunk2 Turbo muffler yet?. im thinking about trying it when i get my Kteller piping and other stuff and was just wondering. the tip might be a little big, like the Apex’I, but im not sure. i may have to just deal with the big tip, seeing as how i really like the look of a straight through muffler of this style, and practically all the turbo apps have a large tip.
Apex’i sounds insane when v-tec hits. I love mine. I have 2.5" downpipe to 2 3/4" mandrel bent to 3" crush bend axle back. Apex’i looks awesome too. As for skunk…i heard that the hi-power was supposed to be reallly loud, but it may be different for the turbo muffler.
Hrm. You don’t want your exhaust to be slowly getting larger, as it finishes.
You want large, then tapering to a smaller exhaust opening, if any taper at all. You are losing power with your setup.
I thought for turbo you want less back pressure…in my case a larger opening as it exits=less backpressure…correct me if im wrong.
you are correct, to a point. its usually a good idea to keep it one diameter though from the turbo back. that way it doesn’t have two pipe sizes to push air through. i’d get the axle back portion mandrel bent to 2.75" or switch to having it ALL 3" mandrel. but depends on your setup. 2.75" is a pretty decent setup for a street car, its likely the way i’m going with mine.
