Stock MAP sensor-->How much boost?
Hey everyone. Im kinda confused on a few things but to start off, i’ve read the turbo guide by haberdasher on the basics of what i needed to turbo my car and yes i’ve done almost a year of research but i think i might’ve read something wrong and probably confused myself but yea here it is
I’ve read using the fmu junk, you need to either install a missing link or throw in a couple check valves for you MAP sensor to function right.
I’m using a chipped obd0 ecu from xenocron (using turboedit) and i was wondering will i need to run a missing link/check valves if i am using a chipped and tuned ecu? I’m going to be running at most 10psi and i wanted to make sure that when it is set there, it wont be running funky since i’m using the stock MAP sensor.
I know i can just change the MAP sensor, but i’m just wondering about the stock one for now.
I’ve read the stock one can read at about 11psi max before acting up. Correct me if i’m wrong.
Thanks much in advance
i believe 10-11psi
if you plan on running around 11 psi id suggest to upgrade to a 2.5 bar map sensor. stock map sensor reads until around 11 psi so you’d be pushing it on the limits.
