Stock turbo?
I want to turbocharge my engine, so what should be the first internals to get changed? I want to do it when I change my clutch, so I can pull my engine, clean the engine up, change some internals. Should I put turbo on with the engine pulled or do it with it in the caR?
read it http://www.g2ic.com/forums/showthread.php?t=80937,
you make it sound so easy, if you got $$$$$$$$$$$$$$ get ur engine built better , that is what i would do
Search. There is a ton of information on this stuff. But for starters, the least you want to change from your stock engine if you’re planning to boost, is headgasket, piston rings, and crankshaft and rod bearings.
And after you’re done reading this, read the turbo guide by Harberdasher at the top of this forum.
-Andrew
