ok so i searched and came up with two diffrent answers. some say yes and some say it wouldnt fit. so which is it, cuz i kinda want one but if it dont work thats ok too :rockon:
i’m almost a hundred percent sure it won’t fit.
jackson racing makes them for our engines, I have seen a couple a GSR’s with them in my area
jackson racing makes one for the engine yes, HOWEVER, if you look like halfway down the FI page you will see the same fucking question. unless you completely remove/move the brake booster and master cylinder then it will not fit.
Now vortech is a different story, the vortech kit for a 99-00 si fits onto a b16 in a 2nd gen teg, there is a member on here that has it. Im not sure about any of the other versions. The vortech is also in the 4-5k range so its exspensive.
by all means please search here http://www.jacksonracing.com/Browse/PlateMenuProducts.aspx?WebCatalogID=16&PlateTypeID=1 and if you find anything that says 90-93 integra, then you are more then welcome to kick me in the nuts
WOW JUST WOW. Just like the finned lines infront of the radiator are for the automatic transmission and NOT the power steering right? Stop spreading misinformation.
There is an argument that the jackson racing supercharger might fit into the DA if 1) your are driving JDM car or car thats been converted to JDM with master cylinder on the opposite side of engine bay. 2) If you can some how relocate the master cylinder and make the pulley on the blower clear the shock tower as it will come pretty close to it . 3) There was a pic circulating on this board a few years ago of a da with a jackson supercharger on the engine in the engine bay. Again something about using mounts that allowed the engine to sit lower or slightly more foward. I dont recall.
A member on here did manage to make a vortec unit fit on their b16a with alot of custom work.
thanks guys, not fitting is what i thought would be the case :bawl: . i was really hoping that it might fit tho. does anyone on here know of any other supercharging companies besides jackson racing and vortech?
there are some vortech look alikes, search honda tech and google i dont remember them off hand
