I’m just wanting to go over every “must-have/must-do” before I begin the work. Looking to get this swap done in a few hours, so I don’t want to run in to any “crap, I forgot to get that” moments. The less down time I suffer on my daily driver, the better.
So far I have…
- A 1991 Acura Integra GS Sedan 5speed w/ ABS, my mostly-stock daily driver.
- A 1996 low-compression JDM b20b with short LS intake manifold and LS head, the most common 96-98 b20b(head recently rebuilt with fel-pro top-end gasket kit)
- An Exedy OEM-replacement clutch kit(clutch, pressure plate, two bearings, grease packet, alignment tool).
- Prothane motor-mount inserts(90-93 Integra).
- Prothane shifter bushings(90-93 Integra, already installed on the linkage set below).
- OEM GSR shift linkage bar, stabilizer bar and shifter + knob.
- Four quarts of Royal Purple 10w30.
- Two bottles of Pennzoil Synchromesh + fluid transfer tube.
- Magnetic oil drain plug.
- STP oil filter.
- Two jugs of coolant.
- Two bottles of power steering fluid.
- Oil pan gasket.
To the best of my knowledge, I have to retain the following from my b18a1 gear…
- Throttle Body
- Fuel Injectors
- Fuel Rail
- Distributor
- Engine harness
- Any sensors that aren’t already on the b20b
- ECU
- Spark plug cables
- Header + downpipe
- Intake
- Engine mounts
- Crank pulley
- Transmission/axles
I still need to buy…
- Idler pulley kit
- Trans seals
- New gasket that goes between header and downpipe(stainless 4-2-1 style, I think the current gasket is fubar)
I may delete the power steering and the a/c. Undecided at this time, may just delete a/c so I don’t have to mess with those lines and possible leaks afterwards.
Does everything above seem correct so far? Is there anything I need to change, or other stuff I need to buy? Anything else I need to retain from my b18a1? Anything in the above b18a1 parts list that I shouldn’t retain? The parts I’ve been buying for the b20b are from AutoZone, purchasing for a 1997 Honda CRV and that has worked fine for me so far. The clutch kit was purchased for a 90-91 Integra.
Should I invest in main seal / main bearings / piston rings for the b20b, or should it be fine as-is? The motor turned over fine with and without the head installed, with head installed I can feel the compression, cylinder walls / pistons / valves looked fine, valve train was nice and clean…so there’s no immediate signs that any problems will occur, crossing my fingers that this car runs and drives like a champ after the swap. :rockon:
