Originally Posted by OZ
FINALLY!!
The moment some people are waiting for:p This is a full Teg Tip submission. Sorry NFULFX, I’d figure I should start showing this to people while you find the time to add this in the Teg Tip page. Anyway, on with the show:
Fig 1.0: Parts needed from left to right -> H4 bulb of your choosing, pair of tin snips, and rubbing alcohol.
Fig 1.1: This is the basic layout of the H4. The H4H by comparison has a smaller mounting plate. So, the object here is to use the tin-snips and reduce the mounting plate so that it can fit in the H4H housing.
Fig 1.2: It’s very important that you do not cut the metal tabs…yet. These tabs perfectly align with the H4H housing. Your goal is to cut off the metal in between the 3 metal tabs.
Fig 1.3: Be careful not to cut off too much metal or you’ll end up cutting off the whole mounting plate which defeats the whole purpose of this excercise.
Fig 1.4: Your bulb should now look like this. Notice I didn’t cut off too much metal. And also notice the 3 metal tabs are still intact.
Fig 1.5: You can skip this step if you like. Personally I like to remove the excess metal off the 3 tabs.
Fig 1.6: The finished product should look like this. You can trim the width of the metal tabs, but do it in very small increments. It’s best to fit the H4 in the housing as snug as possible rather than having it move around a lot. At this point, you may use the rubbing alcohol to clean the bulb. This is a precautionary step that shouldn’t be skipped. You don’t want to waste your time for nothin’.
Overall, each bulb took me 30min. Most of you will probably get this done faster. Personally, I like to take my time when working for my car.
Good luck,
Oz
Next possible Teg Tip -> DIY CAI, stay tuned.
Fig 1.0 -> Parts and Tools
Fig 1.1 -> H4 Layout
Fig 1.2 -> “Ouch” time
Fig 1.3 -> Say to yourself, “Yes this right! I’m not wasting my money!”![]()
Fig 1.4 -> Ain’t done yet
Fig 1.5 -> Taking off what’s not needed
Fig 1.6 -> It’s time to make your Teg look BadA$$
