Teggykid Running Log *New Wheels*
You must have me confused for someone else. I’ve only owned DA’s. NEVER owned a civic or hang out with purp integras.
I’m missing a couple small things like whatever bracket mounts the clutch cable to the tranny, the other half of the shift linkage, my mount is supposed to show up today :D, and maybe a couple other little parts. I kinda realize what I’m missing as I go along since it’s all little, un-obvious stuff. Like the washers/bolt that bolt the stationary bar for the linage to the tranny. If that makes sense. I don’t know the technical name for it haha
Huh. Maybe it was another matt and I thought it was you. Anyways, you got one now? I remember a while back you didn’t have one
Like I said, I’ve only owned a DA and still have one. 2004-06 first DA, 06-current DA.
Got my mount in and on the car. Also, started putting the suspension back together. Put a couple little things back on too. Hooked the rad hoses back up. Like I said, the little things. Here’s a couple pics.
Hell yeah!!! It’s almost done. That mattyg2 guy sounds like a different person now. I wonder if it’s still him or it’s really somebody else. who cares … On to your build now, how much longer do you think it is from firing it up and smashing out on a five speed 2nd gen ?
Well like I said I still need the bracket that holds the clutch cable, the rest of the linkage, and axles? I can’t remember if they were different or not. Oh, and a starter. Need one of those too
Bracket for clutch cable is not needed, but nice to have. It will run against the hood. Good luck finding the bracket though, they can be hard to find sometimes. I would get a DC linkage since you need a linkage. A DA linkage will be harder to find anyways. Axles are the same for auto/manual. The differences are abs and non-abs axles. If you have abs you can fit abs and non-abs axles, but with non abs spindles you can’t use abs axles.
I am the same person.
which bracket you talking about ? the top bracket’s at the valve cover that hold’s the clutch cable from binding, or the one that goes were the clutch adjustment goes ? cause if it is the one for the adjustment on the tranny side I think I may have an extra one but am not so sure you, will have to check with me on that later when you know for sure if that’s the one you need one. I’ll just send it to you for free and you can pay for the shipping.
if you’re talking about the brackets that go on the valve cover they aren’t really needed. since i have a b18c the clutch cable brackets are no good. what i did was i passed the cable under the intake for a cleaner look and i tie wrap it to the 1st and 4th runner of the intake mani. it’s a little ghetto i suppose but i use the beast tie raps and they never broke and it works perfectly fine.
Yeah I’ve heard of people doing that, it’s like tucking it away from the viewers eye, rite ? I was thinking of doing that also but I’ve heard stories that it can make your clutch feel very different. Is that true ?
No I meant whatever literally holds the cable to the tranny. Like it holds the rubber cover that way the wire moves through. I need that, whatever it is. If anyone has a pic of it that’d be great. Like I said it’s my first time doing 5 speed stuff so a lot of this stuff I have to figure out
Oh ok those are the ones that (redintegra) was talkiing about , which go to the valve cover two upper bolts.
Did you understand what i said about were the clutch cable small brackets (2) are bolted up at ?
i noticed absolutely no difference in clutch feel. but he’s talkin about the bracket that mounts on the transmission.
teggykid952 did you check out the scrap yards?? if there’s none your only option is the dealer unless someone here has one lying around but it can’t be that expensive.
Yeah I’ll probably just end up going to my local Honda place. Only have two junkyards around here, and none have 5 speed trannys in them
I’ have an extra one, if it’s the one that holds the cable in place to were you can manually adjustment your clutch freeplay. Let me know if you need it.
Yeah that’s the piece I need man. Can you take a pic of it that way I can see where it mounts? I’m pretty sure I know where it does but clarity never hurt. How much you want for it?
So, for my birthday, my amazing girlfriend is getting me a wink mirror. I really don’t care that it’s a fad, I personally think they are cool. Plus, I don’t have sun visors, so it’d be nice to have something that blocks a little sun. Also getting some stickers from ihatestickers.com, should be pretty sweet.
I will try to post up a pic but I’ dont have acces to a camera just yet but I will still try to find someway how in the next day or so, but I’ve been sorta busy so I’ will let you know. But I’m sure it’s the one. And it i’ll be your birthday gift from me so I won’t charge you but you might have to pay for shipping which is like 6-8 bucks.[QUOTE=teggykid952;2229604]Yeah that’s the piece I need man. Can you take a pic of it that way I can see where it mounts? I’m pretty sure I know where it does but clarity never hurt. How much you want for it?[/QUOTE]
