those with turbo b16a
i would like to no how much boost your running and what have you done to build your blocks up, and are you using a stroker kit or not
My goal is only about 260/wheels at minimum boost levels-like 8-10psi, on stock internals. With the B16’s 10:2 compression tuning is critical to avoid detonating. Right now, everything on the engine is stock, I plan on getting an ITR manifold, GSR cams, cam gears, High flow FUEL RAIL, 450cc injectors, and a Standalone to help me reach my goal.
