[QUOTE=wakaranai;1985038]So what are you suggesting? That you swap an f series or D seires into a DA? Talk about customization.
I agree with you that swapping a k20/24 into a DA is impractical, but why the hatred? Pound per Pound a stock k20a2 vs the pinnacle of B series tech (b18c), the k series will be at par or better.
AND every weakness that you mentioned in the K series, can be aided, upgraded, making the engine more powerful and reliable.
I think it is just a matter of time before we see the real benefits of the K series. The B/D series engines have had 20 years of development. You have to keep that in mind.[/QUOTE]
that is true however swapping a d or f into a da is WAY easier than a k. the hatred comes from the fact that everyone gushes over this series engine simply b/c it has a few technological advantages and makes good power NA. you can do the same thing cheaper with older technology.
and no pound for pound it isn’t necessarily better/faster. honda tuning did an article a while back comparing 2 identical civics, with identical horsepower/weight/etc, one with a k and one with a b. the b powered one was quicker in almost every respect, albiet not by much, but it proves that the k isnt’ all that and a bag of chips and dip.
by the time you upgrade and aid it’s weak points, you will have spent far more $$$ which goes to my original argument. i constantly hear abotu how the K isn’t that expensive, but if you seriously price it out, it is. period. you can buy a used f or b or d, in whatever shape, and spend a fraction of the cost of the k engine itself. i’m sure you can get lucky and find one cheaper, but once the swap is done, you still spend more. depending on the chassis used will bring in factors like the trans tunnel, wiring routing, mounts, cross members, general engine space, exhaust routing, axles, hybrid friendly parts, etc etc etc. those situation do arise in other swaps (d,h,f) but it is far less of a hassle. the hondas from 92-01 were really close to each other. enignes were mounted the same way, so less modification is required.
basically what i’m saying is for all it’s hype the cost to benefit ratio sucks.
i love honda, i love where they were going with the K, but i believe it was executed too fast and too poorly by honda standards. it’s just my opinion.
i’m sorry but if bisimoto can use a NON vtec f series and make enough power to take the all might k swap down, that means a lot. and he did this before he got big.
i’m a huge B series fan. I always have been and I always will be. They are simple, can be quick, and nothing sounds like em.
