[QUOTE=kyle10182;1986995]agree to disagree. i don’t really see it happening.
yea, the itr trans is great. but there is a reason honda stopped making them and moved on to something- wait for it…better. And i don’t need to look at the ratios on paper to know that i can use 1st gear just fine…i guess thats the difference here. i went from a JDM 4.7 fd ITR to a A2 trans and i have personal experience. and first gear has plenty of use.
i guess i need to note sarcasm every time i use it. my 6th gear on the highway is the same as an LS in 5th gear. So i have the 1st-5th of an ITR (or better) and i still have the extra gear for cruising that everyone with a b-series finds their selves wanting to swap out in their ys1’s. I see that gas mileage is a moot point but gearing can help other areas also i have a question for you; do you think that an engine with a larger cam, 12.5:1 compression pistons spinning at 4,000 rpms will last just as long as the an all oem honda engine spinning at 3,000 rpms for its highway life? Is that question clear?
well that’s all subjective. Personally, i trust honda enough to believe that they built an engine, that i love, right the first time. So i’ll leave it be. My point was that i’m sure Honda has a little more hours invested in the R&D of their engines then skunk2 does for example.
Have you ever seen first hand how a power band can transform with the adjustment of that gear?
Ya know how when u go for that $5,000 engine build on your quest to make 220whp and you see those shiny cam gears that you gotta cut your valve cover open for adjustment for? But the problem is that you can only adjust it when the car is off. Well imagine if you can adjust that as your driving down the road, and the ECU is already tuned for each adjustment? that’s bad ass.[/QUOTE]
you can easily see it happening. price it out online. google.com will help.
the reason honda stopped making it was b/c that chassis was 10 years old. if they dont update the cars, they won’t sell anything. that doesn’t necessarily make one better than the other. the cars they put the k into are fat pigs with bullshit suspension setups (except for the tsx). i HATE McPherson struts with a passion of a 1000 blazing suns.
yeah you physically use first gear so what. you have the same crusing gear b/c they jammed that tiny stupid 6th into the case. you aren’t gonna win this one with me man. ive driven enough of them to hate the first gear. if i had a type s, the FIRST mod i’d do is swap in the EP3 5 speed. no question.
you don’t need 6 speeds to road race a honda. period. and not everyone want’s to swap it out in their ys1s. i certainly don’t. you don’t use 5th gear for anythign but highway. the hell with 5th gear. short geared ys1 ratios are VERY close to an itr, so i meet you on that level.
there is NO way to compare longevity dude. imho yes i think so. all things being equal. if you use the same parts honda uses, why shouldnt it? b/c it spins higher? so what. if you track yours more than i track mine, mine will last longer. it’s all relative.
you have any idea how much R&D goes into making quality aftermarket parts?
yes i have seen k series being tuned on a dyno. vtc is convenient and interesting but like i said, doesn’t blow my hair back.
